I'm a fair do-it-yourselfer. I have a 2004 SE. I had it all jacked up and removed the 3 nuts on top and the one big bolt and nut at bottom of the strut assembly; but the spring pushes the strut down and I couldn't get it out. You also need to pull the three bolts on the top straight down to clear the mounting holes. Do I have to drop the lower control arm down to allow the strut assembly to drop clear? I had a pair of spring compressors all ready to install to safely remove the strut and put the new one in the spring but the whole thing HAS to be out of the wheel well for enough clearance.
Hope for any input
Skeater
Hope for any input
Skeater
